NicoR
Certifiably Awesome!
I'll attempt an oversimplification here as to why more power is desirable...
I couldnt agree more, although your oversimplification still sounds complex.
Basically, music has things like snare drum hits and other very dynamic sounds that are louder than the rest of the music. If you're using a low wattage amp completely maxed out, those momentary louder sounds will get compressed, and the music will not sound as dynamic and punchy. If you use a high wattage amplifier with the volume knob turned half up, then you've still got power to spare for all the loud bits in the music.
All other things staying the same, an identical but higher powered amp will sound better than its lower powered brother.
