Try a different preamp with more voltage to the Parasound, been through it before.
What specifically should I look for on a spec sheet? Is it input impedence? Output voltage? I'm not too familiar with this tech stuff. Here are the specs on the Parasound amp and Kenwood preamp. What am I looking for?
HCA-1200 Specifications:
Continuous Power output : 200 watts RMS x 2 @ 8 ohms, 300 watts RMS x 2 @ 4 ohms
Continuous Power output (Mono) 600 watts RMS @ 8 ohms
Current Capacity: 40 amperes continuous, 57 amperes peak
Slew Rate: 100V/msecond
Frequency response: 8Hz-90kHz, +0/-3dB
Total Harmonic Distortion: < 0.08% at full power< 0.03% typical levels
TIM: Unmeasurable
IM distortion: < 0.1%
Dynamic Headroom: > 1.5dB
Input impedance: 30 kW
S/N ratio: >110dB, input shorted, IHF A weighted
Damping factor: Over 120 at 20Hz
Dimensions: 17 1/4" wide x 5 1/2" high x 12" deep; 19" wide using RMK-1000 rack mount
Weight: 38 lbs.
Kenwood Basic C1 Preamp Specifications:
Input sensitivity: 0.25mV (mc), 2.5mV (mm), 150mV (line)
Signal to noise ratio: 70dB (mc), 87dB (mm), 108dB (line)
Frequency response: 1Hz to 250kHz (line)
Subsonic filter: 18Hz, 6dB octave
Total harmonic distortion: 0.004%
Load impedance: 47K ohms
