richardg0n
Greeting AK,
Looking for troubleshooting advice. Restoring another 2325, and after recapping PS, the relay on PS will not open/click when the amps are connected(powered and RCA connected).
PS, amps, Pre, and PU01 have been recapped(see pics). Here is the sequence of steps I have taken to troubleshoot. I am using a DBT, which lights up initially, then dims to the point that the bulb looks off and the relay is not clicking.
1. I checked all the solder points on the PS and amps. Also, as a reference, I compared the solder tracks and points with another primarily original, unmodified amp, P700. Everything looks good.
2. I connected a third amp from another 2325, and there was still no change on the relay.
3. Measured output on P800 J808 and J809, expecting 100mv and got around 6vdc.
4. Checked the output at J804 and J805, and it's 35VDC when not plugged into the DBT.
5. Check all the resistors on P800 and replace a few because they were not to spec.
Advice is much appreciated.
