AR-3a "Cutaway" Loudspeaker Display Speaker
Currently advertised on that auction site. The seller ("acoustic-research-inc" in High Point North Carolina) also posted a cutaway of an AR-11
(more pictures below)
Earlier in the month I came across a very nice pair of AR-3's from an online estate sale auction. They are obviously sought after -- I got caught up in the "soft auction" and they were not cheap. If you've never heard the term "soft auction" before (I hadn't) it means that you do that last minute bidding frenzy like other auction sites -- and
then they keep the auction open until no more bids are coming in.
At least they appear to be worth what I paid for them -- and I don't expect to be so lucky to find a pair of these sitting at a thrift shop around here. These appear to only have been moved from their original "on their side" bookshelf installation perhaps a couple of times in their lifetimes. I haven't tested them yet as the only amplifier I have that is a known quantity is a pair of 1961 Ampex EL34 monoblocks -- which do not have 4ohm taps on their output transformers -- and apparently are a bit underpowered for what is required to really make these sing.
Anyway, I'm just starting the process of trying to find all of the information I can about the AR-3's (circa 1964) and thought that the Acoustic Research fans here would find this interesting:
This one-of-a-kind AR-3a "Cutaway" from Acoustic Research was a show-demonstration version of the AR-3a, hand-made by AR craftsmen in the late winter of 1967 for trade shows and the AR Music Room. Three "Cutaways" were originally fabricated by hand, and the other two were dismantled by AR and destroyed. This last speaker, and original AR-3a prototype, belonged to Delrama International of 1140 Broadway, New York, New York, and was actually one of the AR-3a Prototypes, as noted by the non-painted midrange and tweeter front plates.
This last "Cutaway," no serial number assigned, was to be displayed in Italy, Germany, France, United Kingdom, Asia and other parts of the world. It was shipped to the UK and used for a show and returned, apparently, hardly ever taken from the twin-box (box-within-a-box) special shipping carton, which remains with the speaker.
This "Cutaway" has functioning drivers, but the midrange and tweeter were disconnected with only the woofer in operation, and an audio oscillator, Hewlett-Packard Model 200CD, was used with a power amplifier to allow the Alnico 12-inch AR woofer to pump back and forth at around 5 Hz so audiophiles could observe the operation of an Acoustic Research acoustic-suspension woofer system, considered by many experts through the years to be the finest ever designed for low-distortion bass response.
This AR-3a "Cutaway" is in perfect, original condition, and it has been packed in its original carton for nearly thirty years and displayed only once during that time for the October, 1994 "AR 40th Birthday Party" on the east balcony of Grand Central Terminal in New York City.
This is a very special Acoustic Research loudspeaker and would make a unique and very special "center piece" to a large AR speaker collection.
_______________________________________________
The Acoustic Research AR-3a Loudspeaker:
The AR-3a is a 3-way, full-range, 4-ohm acoustic-suspension loudspeaker—technically a bookshelf speaker for very sturdy bookshelves—which includes the well-known AR 12-inch acoustic-suspension woofer and dome midrange and tweeter drivers, based on the original AR-3.
The AR-3a was designed by Chuck McShane and Roy Allison of Acoustic Research, Inc., and the speaker was introduced at the New York High Fidelity Music Show in October, 1967. The basic design goals of the AR-3a were originally established in 1965-1966 by AR cofounder Edgar Villchur, with the objective of improving the already excellent off-axis dispersion of the renowned AR-3. The result was a speaker containing one of the widest and most uniform midrange and treble dispersion of any forward-facing loudspeaker ever designed for home sound reproduction.
The acoustically sealed, heavily braced (nine internal braces screwed and glued to the inside of the cabinet) and critically damped (the "Q" of the AR-3a is 0.9 - 1.0) AR-3a enclosure volume is 1.7 cu. ft., which is optimal for the 41-43 Hz resonance frequency, and the woofer's suspension restoring force ratio is approximately 85% acoustic and 15% mechanical, far greater than nearly all current consumer loudspeakers using the a/s design. For this reason—and the basic design of the motor system in the AR woofer—the AR-3a has
much lower harmonic distortion than any conventional, current-design loudspeaker of a comparable size. Julian Hirsch measured the woofer's harmonic distortion at a power level
ten-times higher than usual test input voltages, and the distortion in the AR-3a's woofer was under 9% at 20 Hz, setting a new standard of low distortion, especially at this high-power testing.
The woofer used in this pair of AR-3a speakers has a large 9.6 lb Alnico-5 magnet assembly, cast-aluminum frame and a long-throw, 2-inch heavy copper voice coil with a linear excursion of 5/8-inch and a maximum physical excursion of 1.2 inches. The midrange driver has a 1½-inch treated-cloth dome (hemispherical) diaphragm with 1½-inch copper voice coil on an aluminum former assembly. The midrange driver is critically damped with fiberglass pads under and above the dome assembly itself. The magnet assembly is a large ferrite unit. The AR-3a tweeter uses a ¾-inch treated-paper dome diaphragm—similar to the original AR-3 phenolic-dome tweeter—suspended by urethane-polymer foam pieces in the outside portion of the voice coil with a layer of clear butyl-rubber sealing the outside of the magnetic gap. The magnet assembly is ferrite. The drivers have LCR crossover frequencies of 575 Hz and 5,000 Hz.
The speaker's impedance ranges from 2.7 – 4.9 ohms, and the speaker is approximately 0.5% efficient, meaning that an amplifier capable of at least 30-50 watts-per-channel into 4 ohms is the
minimum suitable power. The AR-3a physical dimensions are 14” x 25” x 11-3/8.” The AR-3a’s net weight, each, unboxed, is 54 lbs., and in the double shipping carton 64 lbs gross.
