Those anti recappers can be quite militant!
There's only one way to deal with militants. Pop a recap in their asses.
So, at what year should a total recap be done?
"Once and for all", not too sure it will stick!![]()
When replacing a bad cap in a crossover does one just replace only the bad?
Or just do them all?
I've been accused of being a parts replacer
Won’t modify, the circuit can’t take advantage of the trick wazoo caps.
One of the distributors had a bunch that were failing in that time period. They've since corrected it.I just had a tube amplifier go south that had replacement cans installed in 2003. One started leaking. Still was functioning just leaking oil.
Barney
The argument may be right. But it's weakened by choosing as the main example a Marantz that had been butchered by a previous owner.
A better example would a component in immaculate, original condition, seeming to work properly, and why it still needs a full recap. That would be very persuasive. The existing example is not. It's not yet "the 'link to' once and for all" that you intend.
I have several very good components in original condition and working beautifully. I know the caps are near or past their expiry date and I want to be persuaded.
Thanks Dave. i shortened your comment to the gist, hope you don't mind. You had 2 identical amps, one stock, one recapped, and compared. Moreover, you're experienced in doing such work yourself. So it's informed advice. Thanks.I too have been a want-to-believe guy. I had a chance to listen to my stock, aged, Pioneer SX-1250 next to one that came to me strictly for a controls cleaning but had been re-capped. The recapped unit was cleaner, tighter and with a much improved sound stage. Worth the cost? That I don't know.
That is classic.I absolutely positively don't believe in break-in after a recap, but I still hear it and the sound improves. Maybe I'm just some joker on the internet after all.
Even comments on AK need break in.....although the wording visibly stays the same...I absolutely positively don't believe in break-in after a recap, but I still hear it and the sound improves. Maybe I'm just some joker on the internet after all.
