Seems the consensus is.....20+ years old...if you have to open them up...may as well re-cap while you are in there??
My own personal guideline is seven years. Many people will balk at this, but the operating principle in this issue is YMMV — a lot! I base this opinion on the fact that electrolytic paste is best formed up in a polarized environment. My sources of information over the years have pointed to drift and degradation within the span of a decade. And I mean polarized electrolytic capacitors. It therefor stands to reason that NPE's are more suspect even in this limited time. On the other hand, repairers and hobbyists report that older caps have tested out to be satisfactory.Seems the consensus is.....20+ years old...if you have to open them up...may as well re-cap while you are in there??
Thanks for your very well articulated response, I simply cannot wait to get my CS-99As recapped.
Now for matching a hard cap, do you mean for example a 220uF 50 V cap run 2 110uF 50V caps in parallel? Or maybe 2 110 uF 25V in parallel?
Thanks.
I was surprised to read some years ago an article by an "expert" who cautioned of the same thing. Apparently the drift just takes years longer ... and I suspect has a lot to do with the original quality of the cap. Note: I am not an engineer but just reporting something I read.... Surprisingly, it's not the NPEs that have drifted but the ELCAP polycarbonates.
I am considering re-capping my Infinity RS 2.5s.
I would have to use Bennic electrolytic caps for the big 1100uf (1000+100) and 700uf (500+200).
Considering they're 30 years old, they still sound great. Wondering how much improvement I would hear.
Wow look at the size of those caps!!!
All electrolytic except the mylar on the tweeter. Lots of bundling required:yes:
I recapped pairs of QLS-1s and the Quantum 2.
I believe the combination of replacing the huge electrolytic rolloff capacitors and all the old mylars improved the sound quality in each case. Much better low midrange definition and articuation/separation of the mids and highs.
I thought the current tweeter cap was an electrolytic because it's labeled "electrocap". For the smaller value caps (3.83uF, 50uF and 125uF) I was planning on using metallized polypropylene.
What did you use for the large electrolytics? I was thinking of using Parts Express / Daytons (500+500+100 for the 1100uF, and 500+200 for the 700uF). I don't know much about this, but the size of these new electrolytics seems small compared to the old big cans. Are they up to the task?
I was recommended Bennic electrolytics and would bundle up all the woofer caps with these.
Then I'd opt for using Dayton metalized polypropylene capacitors for the mids and perhaps a nice ClarityCap SA for the tweet.
Madisound has the Bennics and Claritys, Part Express the Daytons.
Have fun!
Thanks. I read somewhere that Bennic is the manufacturer of the PE/Dayton electrolytics, but don't know if that's true.
