Moonwatcher
Hello, all,
I have a Little Bear T11 that I accepts either 6n2 or 12ax7 tubes. There is a switch next to each tube for picking one or the other. The stock 6n2's sound fine, but I wanted to try vintage 12ax7s that I'm pretty sure worked last time I tried them. But not a single one of them lights up, and there is of course no sound.
Would it be OK to try switching to 6n2 for just a few seconds, with the 12ax7s still plugged in, to see if the current even switches over? Any idea what could be causing the problem? Another change needs to be made before flipping the switch over to 12ax7?
Thanks!
P.S. As others have said, putting the metal shield on the far left tube and grounding it definitely minimizes the hum.
Thanks!
