superbob
Hi all, I'm in need of a bit of advice with my Wigo Speakers.
All of the pots are really scratchy and cut in and out, even after a liberal dose of contact cleaner. They also seem to be fully sealed with no real way to open them without extreme force (i.e. power tools).
The pots are all stamped at 8ohm, so I set my multimeter to 200ohms (the lowest it will go).
If I understand it right, if I connect the multimeter to each 'end' it should should show me the maximum ohm of the potentiometer and shouldn't vary when the pot is turned. When the multimeter is connected to one 'end' and the 'wiper', it should show the adjustment of the potentiometer?
Tests as follows:
R1:
Shows 00.5 when both ends are tested, doesn't fluctuate as potentioneter is turned
Shows 00.6 at hard minimum, quickly goes up to 1.2 after a tiny turn, gradually up to 2.2 at half way, down to 1.2 at 3/4 and back to about 00.4 at full.
R2:
Quite similar, but slightly higher values
R3:
Fluctuates between 2.3 and 2.9 as the pot is turned when ends are tested.
Minimum about 00.4, maximum goes from anywhere between 3-6 (the results changed over a few winds of the pot)
Now I'm basically assuming all the pots are stuffed? I've given them all a pretty good run with contact cleaner, the finally alternative would be to desloder them all and soak them in something overnight? I'd be grateful for any ideas of what to soak them in (diesel?)
Apologies for the long winded post that probably doesn't make much sense to anyone but me!
Basically I'm looking to know:
Am I reading the pots right with the multimeter?
What should a healthy 8ohm pot read?
What's a good way to clean them?
Cheers, Bob
Tests as follows:
R1:
R2:
R3:
Cheers, Bob
