WIIM volume into preamp?
Xenomorph
Hi, I hope you're all having a good day.
I've just set up my WIIM Pro Plus with a pre and power amp, what volume should I have on the WIIM? Should I have that at full volume and use the pre amp to control the volume or the other way around?
Thanks in advance.
I have mine set to unity gain with my other sources, which is, iirc, -6dB. Use your preamp’s volume control.
What about a Wiim Ultra that does have volume control (and, importantly, a remote)... before I get one, is it normal to control the overall volume with that, assuming it's using RCA output from Wiim -> amp -> speakers? Asking because it's a vintage amp that does not have a remote.
You need to refer to your Vintage Amplifier user instructions, as it may be possible to overload the amp input if you set the Wiim to maximum volume. One effect of this is to make it difficult to set the right listening volume (with the amp volume control), because the adjustment range becomes compressed. In severe cases only opening the amp volume control slightly making it too loud. ;)
Thankfully it seems Wiim have thought of this and include a nice range of steps of output level adjustment, for example on the Wiim Pro Plus.
Looks like I'll have to read the instructions for a change!
All WiiM models have a volume control, not a remote though. Your suggested set up will work fine.
WiiM has a toggle in settings for max volume to use with a power amp. Have mine connected to a preamp.
I got an Ultra last week and love it. I currently have the WiiM connected directly to a tube amp and control the volume via the WiiM. Works for me.
I've used my WiiM Pro Plus in both ways:
- Directly into one of my power amps, using the WiiM remote or the phone app as a volume control
- As a switched source into my integrated amp. Here I also use the WiiM volume controls as the integrated amp lacks a remote. Typically I set the amp volume at 50%.
In the first configuration you may be confident the missing preamp isn't coloring the sound
Have fun
Tim
My setup is Pro>DAC>Pre>Amp. Until yesterday I had to get up and go to the pre to adjust volume. Such a hardship. Received WiiM remote (original model) late afternoon. Simple to pair in the Home app. Now I can control volume & mute via remote. I already had presets established so the remote knows 1-4. Now I need to find a new exercise since I'm no longer walking the 16' back and to the stereo rack.
Signed,
Idle but happy in Maine
PS: I set the pre volume to 10 o'clock
