Next the new output wires were soldered to their respective locations on the output board and the rear panel was reinstalled.
The RCA input board was then reinstalled
Before reassembling the amp, both heatsinks were given a bath in the sink to get all cleaned up for reinstallation
Along with this, the output devices were also all cleaned up and old thermal compound was removed in preparation for reinstallation.
Next, the driver board was mounted to the clean heatsink and the output devices were installed with fresh micas and thermal compound.
Next the metal separator and pre driver PCB were reinstalled.
At this point the input wires were reattached and that concluded the left channel amp reassembly.
The same process was repeated for the right channel amp assembly.
Lastly, the various ring terminals leading to the power supply and amp boards were reattached to the new filter caps.
Finally the front panel assembly was reinstalled and then it was time for first start and calibration.
All clear on the first start this time around, no issues other than the strange behavior with the new MY2 relays not engaging.
After spending quite a while dialing in the calibration, I brought down the matching C-2A I previously restored for a first listen.
And we are done! Everything is now sorted and the M-2 Lives again!
After spending a few days with it in my main system and needles to say I'm quite happy with it. I hope you all find this thread useful!
