I've had one for about a year and I'm very impressed - but then it is my first tube amplifier. When I compared the competing models at China-HiFi, it had the features I required and it had one of the best exterior designs. What really sealed the deal was that it weighed a bit more that the comparable Line Magnetic and Muzicshare, etc. I also preferred the big 6SL7/6SN7 signal tubes in the front end over the miniature 12AX7/ 12AU7 tubes which are more prone to microphonics. I've had no problems with the amp so far.
The weakest part is the front end. I recently bought an expensive new Luxman tube pre-amp to use the "pre-amp in" input and it sounded even better - more solid and full and quieter. It better at 4X the price! But then, it has a wooden cabinet so I was seduced by a pretty face.
I ordered the KT88 model and have since rolled in KT90s and EH6CA7s. I found I like the KT90s in triode mode better that either mode for the OEM KT88s. The EH6CA7s sound even better except that the bass is sloppy on the Forte IIIs in both triode and UL. There might be confounding changes responsible - I'm still playing with the 6CA7s.
I also replaced the OEM front end 6SL7s with Gold Pin Tung-Sol 6SL7 and also noticed a slight improvement but I'm not sure they were worth the $100/pair plus shipping.
I've got a pair of new Tung-Sol 6SN7s for the drivers coming along with a quad of Tung-Sol EL34Bs. Down the line I intend to get a quad of KT77s and a quad of Gold Lion KT88s to try. 6550s also work but they are at the bottom of my testing priorities.
So yes, great piece of gear for the money but the differences between the Line Magnetic and Muzicshare look to be minor.
