Winter time vinyl issues.
Ken Boyd
Well I just went thru a few hours working on my table to fix an issue that was a real annoying distraction, loud pops which sounded like major artifacts in the groove. Loud pops like the needle hitting something in the groove, or jumping the groove to the next track, but it wasn't that as it wasn't skipping a track or jumping forward to the next track.
The tone arm I have uses dynamic tracking and antiskating as it uses a magnetic means to accomplish the antiskating. The knob on the antiskating has always been loose so that was my first thought. I had a blank vinyl disc and the arm when lowered on the blank record would race to the center. No matter what setting I did it wouldn't change so I knew something was not right with that. Ended up having to remove the arm and remove the knob by a small screw from underneath, then clocking the gear to match the location on the knob and then lower the knob so the gear teeth matched and then tighten the screw. Antiskating was now worki8ng correctly, except I needed to relevel the table. Much better but still for no reason a pop here and there. Checked and set the tracking force good right at what I run this cart a hair over 2 grams.
Then I started thinking what has changed, the weather! It was cold and dry today, our first real cold front. Not cold as far as many of the other states but the dew point and humidity is much lower than it's been all year. I had noticed a few records earlier the same issue and I ran them thru the Ultra Sonic cleaner and the pops went away, I was a bit mystified as they looked spotless but after the US cleaner, they were quiet. But what it was wasn't any dust, it was the moisture which eliminated the static charge. After doing all that all I really needed was a brush with a record brush with a spray of cleaner or a shot with the anti-static gun. The needle was creating a charge from the friction and when the charge reached a certian potential it would discharge into the cart.
So just a word out there with winter and low humidity you need to consider some changes. Mist your records or use a gun to remove the static prior to playing them.
