corpblues
AK Member
I bought a Wollensak T-1980 Reel To Reel Tape Recorder from an estate sale. It powers up and the amps work. I tested the amps in PA mode using a microphone.
Any love for old Wollensak Tube reel to reel tape recorders?
Does anyone have a manual?
Initially it will spin the hubs in ff/rew but it would not play.
4+ hours later... Tired but feeling pretty good about the progress thus far. Putting this out here to help anyone else trying to figure out how to disasseble it.
I fully disassembled it. Had to take both amps out first. Then removed two rails that are bolted on to the cabinet that both support the deck and the one on the right has a mechanical lever that turns the amps on/off from a connecting rod on the transport.
Took the faceplate off and lubricated all the moving levers and bearings. Got it to where it would then play pretty well but would bind up sometime and always bind whenever I tried to fastfoward. Finally figured out the right spindle was not turning well. So took both spindles off and oiled the bearings and now it works nicely in play / reverse / fast forward. Start and stops nicely, rewinds and fast forward nicely and switches speeds nicely.
I've reassembled the transport. Getting too late tonight, so will hook everything up tomorrow and see if it will actually play a tape.
