Wonder What's Inside?
That would be cool...eh? Do you think there would be enough air flow with just yhose holes in the backs?
Lets assume there's some openings in the bottom as well for inlet air, but even if not, the location and dual rows of holes would allow for fair convection.
I just bought a pair of Paradigm 5se's from that guy. It took a month to get them, but the deal couldnt be beat. Just an FYI for any potential buyers from him.
D
That whole transformerless thing is not the huge issue folks make it out to be. It is a problem when connecting to grounded items, but use of an isolation transformer or using caps to tie to the chassis instead of a wire will isolate it nicely. Probably nothing super special in regards to the amps, probably 50c5 or something of that nature. Maybe if you're lucky a pair of 50L6 tubes and a 35 volt rectifier tube. That actually wouldn't be a half bad little amp.
That's what I meant, not a lot of people know about caps and isolation transformers, and now all outlets are grounded...
