Wood case for Marantz 5020 cassette deck
DKWrider
I have seen various references to the model number of the walnut case for the Marantz 5020 deck, so I am not sure which number is correct. Does anyone know the correct WC number or where I can purchase a replica?
THANKS!
I had seen that case identified for the 5020 player. I have a 2238 receiver with an OEM case. That case measures 15 inches deep to match the depth of the receiver. I think the case is a WC-22. If so then that case seems too deep for the cassette player since it is only 11.5 inches deep.
I read somewhere that the 5020 took a WC-153. Any information on that case?
THANKS!
If it is being displayed near a receiver in a WC-22, it will look much better if it is also in a WC-22. The fact that the back of the deck is 4" short of the case can't be seen from the front. It looks like the proper case. I bought a 2245 new in 1972, and a 5020 in about 1974. Both were in WC-22's and looked great together.
Its a WC-122 it fits the same models as WC-22 and comes in 3 pieces
Thanks. So it looks like the 122 designates the three piece case instead of a cabinet.
By that logic the WC-153 would be a three piece case version of a WC-53 cabinet, but I have not seen any reference to a cabinet with that number.
Here is the post where I saw the reference to a WC-153 for the 5020:
https://audiokarma.org/forums/index...rmation-site-found-super.197373/#post-2306844
For a receiver, I would think that the three piece case would provide better cooling but not applicable to the cassette deck since it does not have any ventilation requirement.
Maybe the WC-22U is shorter? I have a reproduction WC-22 type on a 5020. It's shorter without a vent screen. I put a model 120 scoped tuner in a WC-22. It's not as deep as a receiver, but it's not really a problem. I also had the same
WC-22 on a 5220 tape deck until it died.
My 5030b came with what I believe is a WC-121, I'd rather have the WC-22 style case.
Still need to stain the replacement walnut veneer strips.
I bought my 2238 in Los Angeles in 1977 and bought the Marantz case to go with it. My case does not look like the ones I have seen for sale. Mine has vents on top and sidesView attachment 2438399View attachment 2438400 View attachment 2438401
If you look at the 25th anniversary brochure (1977?), it has all the receivers photographed in the WC-122 case, and they're the then-new silver-face B series. Believe that's the correct case for those models. The cassette decks I've come across with cases had a smaller version of the WC-122 on them (WC-121?).
Believe Marantz changed the case design when they introduced the silver-faced B models.
https://www.hifiengine.com/manual_library/marantz/25th-anniversary.shtml
Haven't had luck finding a WC-122 for my 2252B. Finally used the scrap from my record shelf/stereo stand (CP#1) to build a variation of a WC-122.
At the same time they changed the cases, they changed the top cover of the receivers, taking out the side vents. My 2252B doesn't have side vents, so I didn't cut any on the sides of the case.
But if those models can't be found, it fits a WC-22 perfectly except for the length
i dont think the WC-153 will fit, i looked at the 5020 owners manual and it says a WC-15T is the case to use. it also gives the dimensions for the opening. you can download the free manual at https://www.hifiengine.com/manual_library/marantz/5020.shtml
The WC-15T is the full cabinet version. A WC-153 is a three sided case. Since the first two numbers are the same, maybe the WC-153 will fit. I think I would rather have a three sided case since that is what I have on my receiver. If I can’t figure out the right number AND find one for sale, then it looks like a WC-22 is an option unless someone could build a WC-122
Go ahead, call me a looney, but I think the proper case is required. Have to send some muscle to get Aaron on board with a WC-122 kit:whip:
