ScooterMcTav
I know less than I think
Hello All,
After purchasing a set of nice Soliloquy 6.2 speakers last year, I painted them grey to blend in with our new home's decor. Although they look fine, I was considering selling them, which means I need a strip and refinish. Or, I'll like the results of the refinish so much, they may move back into the main system (if I can tweak the x-overs a bit to fill the sound while I have them apart).
Them in their original color:
Pretty horrible, and actually a lot more red in person. Very Pecan-y. Now in Grey:
So I figure that when I'm done chemically stripping them, it will take off the grey paint, as well as the varnish or seal on top of the factory color. Then I'm a bit befuzzled as to what to do. Of note, I am unsure of the veneer species; though it has a very smooth texture without many carbon marks, so I'm going to guess birch. Also interesting to note that a clear birch was one of the colors offered.
Now ideally, I was thinking in a few different directions:
- If the color is dye, not pigment, I can bleach it out of the wood returning it to a birch-ish color. I can then hand rub in a few coats of Minwax ebony stain, making them mainly black, but with some wood tone and texture to it, finishing with a satin finish lacquer or urethane
- If the color is pigment, I then rub in a green stain to bring them to a darker walnut color. I then add some ebony on top to darken them down to almost a black mahogany. Then finish with a satin lacquer or urethane.
In either case, I have read a recommendation to let a heavy coat of the black dry on, then do a light sand to darken the deeper and more absorbant areas of the speakers. Sanding veneer gives me the heebie jeebies, especially as these guys still have crisp corners and edges on them. That being said, when one googles these speakers, many of the same color have a nicer tonal texture (IMHO) than the bland caramel pudding of mine.
So what are the thoughts of this approach, and has someone done something similar? Anything I'm forgetting in steps between the strip and stain that would make my life easier?
Open to suggestions and recommendations. And do we have a guess as to if the original finish was dye or pigment?
