jeffn
Mid-Fi Crisis
rulerboyz said:About 68-70 F inside. 14 F outside. Pretty dry too.
Outside its minus 10 Celcius.......... thats BELOW FREEZING?
Hell, no wonder its taking a while to dry, even inside.
outlawmws said:Also is that "Dry" outside or inside? because houses commonly are very "wet" compared to the outside in winter...:yes:
jasong said:I beg to differ. In my part of Canada, houses are extremely dry inside in the winter. The outside air can be rather humid, but in heating air, every 20°F of heating drops the RH by half. Many homes in Canada are actually quite dry inside. This likely holds somewhat true for Ontario, although the best way to tell would be to have/look at an RH gauge in the house.
outlawmws said:Didn't notice he was in Canada, and unless you heat with a wood stove in Calif. the opposite is true. I'm usually 10-20% wetter inside than outside.
outlawmws said:Uh... Wrong forum?![]()
gearhead said:Well, alrighty then.
Ideally-how thick should the glue be?
Wow... looks like a galaxy or something! Neat!Mopic5 said:
