fredmarantz
Well-Known Member
I have a Marantz cassette deck 1810 do they make a wooden case for this model?
I don't think so....
regards
Freddy
I have an 1180DC in what I believe to be an original wc-110 wood top case, pic attached. I’ve seen other cases with the metal vents, including the manual pic but this unit just has slots cut out. They are very thin and I’m worried they do not vent well. I know the 1180dc runs pretty hot but after about 30 minutes of running it’s extremely hot, I can feel the heat around the console and smell the unit. Should I be worried or is the venting sufficient? I’ve had no luck tracking down a metal case and not a big fan of the non original eBay wood cases.
View attachment 2616264 View attachment 2616265
Nice case, but doesn't look too efficient with regard to circulation. Not familiar with the 110, but the 122 had side vents as well as the vents on the top. I've seen photos of a 110 type case where there are two open rectangles where the slots are on your case, and they had wire mesh fitted in so it was flush with the wood on top. Looked very well done and like it would "breath" easily.
What's the situation on the bottom? the idea is to have the hot air vent out the top and draw cooler air in through the bottom. So the bottom should have an opening/s under the heat sinks.
Yeah that is not near enough ventilation in that console. You need a minimum of 3 or 4 inches above the amp. For low volume it may be alright, but I would never crank it much past 9:00 like that for very long.Has the standard metal bottom but not a ton of venting. The case you’re describing sound like the pictured one in my manual and I agree, it looks very efficient. The metal case seams to vent on the sides as well, which I think would really help since the power board is on the side but just not having any luck finding one.
It’s a shame because the case is mint and I have a matching 21xx tuner case but it’s already a tight fit in my console and I can feel the heat transferring through the console onto the records.
View attachment 2616446 View attachment 2616458
Would a case that’s on a 4415 also fit a 5220 then?New Version
WC-1:
10B, 20, 23, 30, 120, 120B, 115, 115B, 125, 150, 1120, 1150, 1150D, 1200, 1200B, 1250, 4100, 4140,
WC-1U:
510M
WC-2:
7 & 7T (without the vent) 15, 16, 32, 33, 240, 250, 250M, 510, 510M, 3300, 3600, 3800, 4000
WC-4:
22
WC-5:
26
WC-9:
19
WC-10:
104, 105, 105-B, 110, 112, 140, 1030, 1040, 1060, 1070, 2010, 2015, 3200, 4060, 4070, 4220,
WC-22/42:
2215, 2220, 2220-B, 2225, 2230, 2240, 2245, 2250, 2270, 2275. 2440, 4230, 4240, 4270, 4415, 4430, 5020
WC-43:
2325, 4300, 4400
WC-110:
170DC, 300DC, 1090, 1122DC, 1152DC, 1180DC,
WC-116:
2216B, 2218
WC-122:
2216B, 2216B(L), 2226B, 2226B(L),2238B, 2238B(L), 2252B, 2265B, 2285B
WC-123:
2330B
WC-124:
2385, 2500, 2600
WC-130:
1300DC
WC-136:
2100, 2100L, 2120, 3250, 3250B, 3650
WC-153:
5010, 5025, 5030
WC-160:
1050, 1072
WCV-115:
1515, 1515L, 1530, 1530L, 1550, 1550L, MR-215L, MR-230L, MR-250L
WCV-125:
1820MKII, 2020, 2020L, 2050, 2050L, 5000
WVTC:
SR-1000, SR-2000, SR-4000, SR-6000
B18-0:
18
Michael-Otto
New Version
WC-1:
WC-1U:
510M
WC-2:
WC-4:
22
WC-5:
26
WC-9:
19
WC-10:
WC-22/42:
WC-43:
2325, 4300, 4400
WC-110:
WC-116:
2216B, 2218
WC-122:
WC-123:
2330B
WC-124:
2385, 2500, 2600
WC-130:
1300DC
WC-136:
WC-153:
5010, 5025, 5030
WC-160:
1050, 1072
WCV-115:
WCV-125:
WVTC:
B18-0:
18
Michael-Otto
it uses the WC-1I scanned this thread and did not see the model 24 cabinet number.
I want to match mine up with a model 16 (which uses the WC-1 cabinet)
Did the model 24 use the WC-1? or maybe the WC-2 ?
thanks,
Tom
