VintageDutch
I know Rotel is not a very popular brand in the Netherlands but the do made pretty nice stuff... or had it had in made in Japan...and it survived the test of time... so they did it right...
Recently I found and bought a bit rundown ROTEL 602 in full working order, light burning and everything but in need of lots of TLC..
This week I needed some "me and my machine" time and started working on it...
First thing I tackled was the dirt on the scale and fascia window...
Before:
As you can see it is a pretty long receiver...What is not seen on this picture it the rough state of the wood cabinet (and I do not have a picture showing it...) and also the grime and dirt as barely visual..but believe me... it is there...
So took of the knobs (see my post about the volume knob) and removed the fascia or front and cleaned it with some warm soapy water...While that fascia was playing in it bathtub I removed the black/green scale and also gave the a nice soapy bath ...even removed the light reflector metal and cleaned it.
After it was cleaned some more signs of neglect got better visual... scratched Plexiglas in the fascia, so out came the polish cloth and commandant polish... that did the trick .
After putting it all back together again I replaced the fuse lights with new warm white led fuse lights...
Now look at her shine
It is a hack of a lot nicer and more sharp..
Still a long way to go.... Next plan is recap the power amp and supply and attack the grime and dirt on the "wood" foil cabinet..see if and how it can be saved or should be re-foiled...
anyone tips ?
Before:
anyone tips ?
