Excellent work!!! Great pictures too. When will you test it with music?
The sound it is putting out so far is just astonishing, it has so much more depth than im used to, especially with instruments where you hear the entire action and not just the resulting note.
Sanded the scratches out of the face and blended it in with the existing finish - filed and refinished the bezel sides from where the amp has been smacked into things also]
AOK, can you describe how you sanded off the scratches on the faceplate without taking off the anodizing? Concerned readers want to know....:yes:
There are different processes, and different results, but if you know anything about aluminum, it must be protected from the air to look nice, via a polish, clear lacquer or enamel, or anodizing. As far as this particular Marantz, the faceplate is anodized. Once the hard coating is removed, the surface oxidizes, forming an aluminum oxide coating (what else?) a few molecules thick. Aluminum oxide is unsightly in most forms, and unless protected in some way, will require constant maintenance in the form of polishing in order to keep it looking nice. In addition, once the anodizing is removed, it is usually impossible to make that section match other sections which have not been sanded.Hey all, the faceplate really wasn't that bad to do i dont think mine was anodized to be honest just seems like a sanded finish.
I've passed on a lot of otherwise nice gear when shopping around because the faceplate had been sanded. I strongly discourage it. But it's your gear, so if you know the downsides and are willing to trade a dinged-up faceplate for a ruined one, go for it. I'd consider doing it only for a faceplate that was so bad it would otherwise be considered unusable.
I don't know about sanding a Marantz faceplate, but I definitely wouldn't sand the knobs.
na there is no way you would do that, the finish is impossible to recreate. When i said sanding the faceplate i used it very loosely aswell. It was more like a light rub to blend the scratch into the plate...
An interesting thing i found with this amp aswell is how susceptable it is to interference. I had it on the ground and was putting it through some tests when it started buzzing, when tilted it on its side the buzzing went away, i was baffled, then i lifted it off the ground and the buzzing went away. I put the bottom cover back on the amp and it went away aswell, seems they really need that shielding...
I love the pic of that 2275, its my inspirationat the end of this i will have to replace a nob or 2 aswell
It was a bit of a tight fit with those bypass caps, should have seen me trying to get the iron in around all the wires LOL!
