JonL
Lunatic Member
The key word is should.![]()
Precisely. :yes:
Did you wrap teflon tape around the prongs of the plugs as you usually do? Was wondering if this is needed when using a Maestro.
The power lines do vibrate A LOT and this tweak helps dampen those vibrations in the power lines and lowers the noise floor. This tweak takes the maestro outlets to a whole new level.
You're not going to try it, finnbow?
I am. I have some tape left over from a plumbing project. Why not? Nothing to loose and it'll cost me zip.
Nope. Laziness and skepticism prevail at Chez Finnbow.
Or maybe even use the yellow teflon tape that's rated for gas line threads?
I like the yellow tape, it seems to be easier to work with.
Yes, I'm still putting the teflon tape on my ac prongs. Great tweak too! The power lines do vibrate A LOT and this tweak helps dampen those vibrations in the power lines and lowers the noise floor. This tweak takes the maestro outlets to a whole new level !.. Here's pictures of the teflon tape tweak.... http://www.audioasylum.com/audio/tweaks/messages/16/165450.html
Actually, he's just getting started . Taping up all the wires would take forever! Maybe I should just stick with the Maestro?Just how many new levels are there, anyway?
However, if I have no issue pruning away any threadcraps that come along.
