I’ve got a lathe, mill, mig/Tig, plasma cutter etc out in the shop. I also have a 10” table saw, planer, jointer, etc.
I also have a 3D printer.
Out of those options, the 3d printer would be my last choice for making speaker enclosures. The first choice would be the woodworking tools. Not because its “traditional”, but because the wood/mdf has better “vibration damping” properties over plastic, is a speaker box application.
The plastic can be designed with bracing to try and damp resonances, but the wood is always goi g to be superior.
Not to mention, it will take days (to weeks) to print a single full enclosure while it a lazy afternoon of work in the table saw to make several in wood/mdf.
3D printer more useful for little bits like wire organizer's:
and perhaps knobs and other little plastic bits that you can’t buy any longer.
But its not a “do-all” tool as some seem to think.
When I needed a “tape splicer”, I printed one off in abs first. Downloaded the stl file from thingiverse to try it as it looked fairly slick. Did it work? Not really. Kinda, sorta, maybe, mighta if I was willing to be frustrated by it every time and ruined a lot of tapes, splice tape, etc.
So I reworked the design and made it on the mill:
works great in aluminum. Absolutely perfect cuts and splices every single time without having to put a lot of thought into it. The “machine” does the work. The ABS version went into the plastic recycling bin.
Then again, when I needed a new combo gear for the change drive in my 1954 Atlas lathe, I 3d printed a new gear in abs and its been running fine for the past two years:
In fact, it runs better than the orginal gear becuase the formely loud and metal ringing the gear drive used to make is now gone. The metal ring noises are absorbed by the abs gear and the end result is a much quieter machine. Theres a bit more going on there than just absorbing vibration, but thats it in a nutshell.
the 3D printer is a valuble tool in the box, but its not for everything. Just as the table saw is not, nor are the metal working tools.
If I were to hazard a guess as to why everyone seems to think 3D printers can make whatever they want, I’d say it a combination of factors: everyone’s used to everything being made of plastic these days and its relatively “low skill” to buy a retail 3d printer, load up some filament, load up an stl file and out pops what (they think) they want out of “thin air”. It’s a little bit more complicated than that, but the “computer generation” seems to understand it more easily than metal or wood shop type work.
You fire up the table saw or the mill with the same general lack of knowledge/skill and you’ll be missing digits (or worse) is pretty short order. Worse thing you’ll get from a 3D printer is a 1st or 2nd degree burn on a fingertip…
