I know about quad receivers, I am looking for a good deal on a Sansui QRX-6500. This appears (to me) To be the best Quad receiver. any suggestions or reccomendations would be appreciated.
The late Sansui QRX series receivers were outstanding quadraphonic units. The top of the line QRX-9001 is the very best quadraphonic receiver ever made.
Here's the thing though, (keep in mind that this is all new to me), As far as I know, the only way to get true quad sound is from a Reel to Reel and 8 track tapes. Is there anything else I'm missing. CDs and LP's would be cool, but I don't think they exist. I heard that some fm stations broadcasted in Quad back in the 70's, but that's about it.
Quadraphonic era sounces:
Q4 -> quadraphonic reel-to-reel discrete four channel tape. The very best quadraphonic era source material. The good news is that these tapes can sound excellent. The bad news is that there were far fewer titles released in this format and they were expensive then and remain so in today’s secondary market.
Q8 -> quadraphonic 8-track discrete four channel tape. This format was very popular with many titles released. The bad news is that Q8 tapes suffer from all the ills of the 8-track format. i.e. poor signal to noise ratio, wow and flutter, tape and cartridge failure over time.
CD-4 -> quadraphonic discrete four channel phonograph records. With proper set up these discs can sound very good and very discrete. The bad news is that set up is a bit tricky, a special cartridge and demodulator is required and CD-4 records that have been played with a conventional two-channel cartridge may be damaged and no longer playable in quadraphonic mode. There were quite a few titles released, however, CD-4 records were not the most popular format.
SQ -> matrix quadraphonic phonograph records. SQ records used a matrix to encode four channels onto a two channel record. Upon playback through a proper SQ matrix decoder the four channels were reconstituted. No special cartridge is required to play back these quadraphonic records. The good news is that SQ was the most popular quadraphonic format with thousands of titles released. The bad news is that the separation and “discretemess” was not as good as the truly discrete formats.
QS -> matrix quadraphonic phonograph records. QS records used a matrix to encode four channels onto a two channel record. Upon playback through a proper QS matrix decoder the four channels were reconstituted. No special cartridge is required to play back these quadraphonic records. The QS was not nearly as popular as the SQ format. The bad news is that the separation and “discretemess” was not as good as the truly discrete formats.
Dolby Surround -> technically this is not a quadraphonic era format, however, Dolby Surround is a matrix encoded four channel system. When played back through a QRX series receiver’s matrix decoder, one can expect excellent results. Some Dolby Surround music CD’s have been released and are available and there are thousands of Dolby Surround VHS tape and DVD discs so encoded.
The Sansui QRX series receivers have excellent matrix decoders which is good news if you purchase matrix encoded quadraphonic records or Dolby Surround encoded CD’s or DVD’s. The QRX-9001 (and maybe other Sansui QRX series receivers) also has an excellent CD-4 demodulator built into it.
Modern universal (dts-CD, Dolby Digital, SACD, DVD-A) disc players can also be used to source discrete four-channel sound to a quadraphonic era receiver. This is an approach that I highly recommend.
