Write a sentence using a song title
SuperjazzyJa
18 Wheel Member
Yep!
Write a sentence where you incorporate a song title, any genre. The trick is you can't just put the song's name in like "I heard 'Pinball Wizard in the diner.". You have to change it up, like "The Pinball Wizard was at the local arcade this morning."
On my last Sailing¹ trip, I saw Goats on a Boat².
1. Christopher Cross
2. The Devil Wears Prada
After properly arranging the logs in the fireplace, you set them Ablaze¹ using The Kindling² wood. Then, your home will no longer be Frozen Inside³ because the Holy Fire⁴ will roar, but make sure that all the windows and doors are closed and the place is insulated so that the heat doesn't Get out⁵. You would then have the temperature go up by +0⁶ degrees and that would be Offensive⁷.
1 & 6. Saving Grace
2. Antestor
3. HB
4. Bloodgood
5. Antidemon
7. Metanoia
"Hello¹" said I to my friend, the Green Eyed Lady² when we met for coffee. I Believe³ she got up and was out the door in a Moment's Notice⁴ but she wasn't fully Awake⁵.
1. Lionel Ritchie
2. Sugarloaf
3. Blessid Union of Souls
4. John Coltrane
5. Deliverance
