Carbsandcaps
Wasn’t sure if anyone would be interested in seeing this but this is a ww2 Morse code training keying machine.
I bought basically because it was cheap and I was considering turning it into some kind of amplifier but it’s just too cool to cut up. It has the original key and I just put a cheap speaker in the case. And it’s heavy! I could figure out why it had such a big amplifier just to make dots and dashes then I read that it was supposed to be used with up to 300 headphones.
The way it works is it has a light sensor that inside the brass bulb that reads the dots and dashes on the tape real. It has a tiny hole in the brass bulb to let light in. Then it converts it to dots and dashes. I had to repair the idler wheel I just used a few rubber o-rings. It works great and is super cool. Definitely a piece of American history.
