ssouci
Well-Known Member
HELP!
I recently did some work on my Fisher X-202
upon turning it back on, it started playing, but it sounded odd and I heard a lot of general distortion (at least in the R speaker, which I was sitting beside)... then I noticed one of the four output tubes was glowing BRIGHT RED, so I immediately turned the amp off... YIKES... had it on for perhaps 1 minute(?), after the soft-start completed
it all happened so quickly, but it seems that only one tube redplated
after turning off and waiting a minute or so, I touched all tubes... 3 were only slightly warm, but one was noticeably hot (the redplating one)
the work I performed was bypassing / disabling all of the slider switches (which I always kept OFF anyway), in an effort to take all dirt-prone switch contacts out of the signal path permanently... in each case, I modified so that the normal state was now permanent OFF, and putting the switch to ON would do nothing
I did these switches:
1. Phase Reverse (wired the R speaker "directly", same as the L)
2. Tape Monitor (relocated wires on switch)
3. High Filter (relocated wires on switch)
4. Low Filter (placed jumper wires across terminal strips, where long wires leading to switch originated)
(did not do Center Channel switch, because OFF state seems to be signal not passing through any contacts)
the amp was playing FINE before the work, so I'm guessing I disturbed something, or made a mistake... I checked my work carefully, but who knows?... or perhaps overheated an attached component while soldering? (carbon resistor, ceramic cap)
NOTES:
- tube ID that redplated was "V12"
- output tubes are vintage Russian equivalents to 7189s (the 10,000 hour ones)... they have maybe 1,500 hours now
- this amp was modified earlier with individual tube biasing... I've always biased the tubes precisely (~29 mv), and don't think I accidentally disturbed any of the bias setting knobs when I was working (since they are so inset)
Q: what could have possibly gone wrong, and how should I proceed... hopefully so that I don't wreck my amp or the output tubes!?
thank you!
NOTES:
thank you!
