X202B: High Frequency Response
nate867
Hello,
I have an X202B I've restored and use almost daily. I've done a fair amount of work: all the usual steps, plus replacing worn tube sockets, eliminating the remote control circuitry, etc. Now I want to check/ adjust the high frequency response, since to me the unit sounds a little "edgy." I scoped a 2khz square wave both at the recording output jacks (after V3) and at the speaker output (going into an 8 ohm dummy load.) Attached images show an overshoot that suggests I need to tame the HF a bit.
I've read in the previous thread "Gilding the X-202B" that the relevant caps are C9 + C10, and C19 + C20. I'm thinking I should adjust C9-C10 for a flat response from the recording output jacks, then the 2nd pair measured at a point further down the line. Perhaps at the input to the volume control?
Is there any general advice on tackling this area? Do people just tack additional caps in parallel by trial and error? Would I have to adjust any other components? This is getting deeper into the engineering side of things than I've done before.
I will note that the line stage tubes are Telefunken 12ax7 and Mullard 7247, which test good in my Eico 667 and seem ok. But I suppose I could swap tubes in and out and check the square wave again...
Thanks!
Nate
In my experience, those caps tend to over-compensate slightly even in the stock build. If you removed the shielded cable associated with the remote control socket, that would only act to accentuate the over-compensation. When I make adjustments to the compensation caps, I always completely remove the old ones, and then install appropriate new silver mica ones to make the correction.
I hope this helps!
Dave
Thanks Dave! Yeah I figured from reading your previous threads that the work I did would tend to accentuate it. I will follow up on this thread with new measurements after I'm able to get back in there.
Hello,
So after auditioning a 15pf cap for C9/C10 (stock is 21pf), I landed on a 10pf cap (a C0G 630v ceramic). This reduced the overshoot substantially when measured at the record out (now at 3%). Measured at the input to the volume pot I'm getting slightly more (6.5%). I haven't tried reducing C19/20, maybe it isn't necessary? How flat does flat get with a 2khz square wave in the stock X202B?
Measured at the speaker output, centering the treble control creates a HF rolloff, but it can be changed with a slight adjustment. This does create the beginnings of ringing... But in practice, is this worth further testing? (There may be artifacts from the probe etc.) Or would folks just call it a day.
Hope this info is helpful to somebody!
