X3X Dial Pointer Broke
SG19
AK Subscriber
I was turning my SX-535 around and snapped my dial pointer off right next to the lamp, any glue recommendations , I don't want to use something that will block light transmission , wondering if someone has used something that allowed the red tip to light up ?
Thanks for the link , I'll check that out , ATO Audio , I've watched some of his youtube video's.
I'm considering using this for glue ,
I'm betting that will work--it's cyanoacrylate, should be transparent enough to transmit light with little reduction.
Sounds like you are happy with the amount of light transferred using the Gorilla glue ?
I talked to Mike at ATO , he said he's had someone use it on a 535 , the photos look identical to mine , it's $35 for his kit , doesn't sell the pointer separate, he tells me that if you glue it light doesn't transfer well, not so sure about that , I don't need the light and other stuff in the kit , just the pointer.
I already bought a complete LED lighting kit from Joe's Quality Wholesale Lamps that paintedtoad recommended so I'm going to give the $4.99 loctite a try.
Thanks for your reply
i used plain ole superglue on my sx1010 but i glued it back together ever so slightly crooked. it drove me nuts too so be careful.
eventually i was whining about it in a thread on here and another member had one and sold it to me.
paintedtoad
painttoad, i am a toad, not a turtle.:naughty:
OMG my bad , sorry about that, I've been reading that in my head when I look at your screen name , I'm a dumb ass sometimes.
There's not too much to work with thats for sure , I was trying to be so careful, you don't get a second chance with it thats for sure.
I did the same with a Marantz a long time ago, but do remember using plain ole super glue. Worked fine.
It seems fine to me. I mean, I'm sure it isn't quite as bright as an unbroken dial pointer would be. But it's entirely satisfactory as far as I'm concerned. And it *is* the cheapest solution! (I happened to have a tube already.) I did manage to get my pointer aligned pretty well at the break because Gorilla Glue probably sets a good bit slower than standard superglue. It was runnier than I anticipated--I did get a bit down the side of the pointer I wasn't able to get off completely. But it's really not noticeable much at all, and I'm not anal about how pristine the pointer is.
Been searching for a couple weeks now without much luck. Does anyone out in AK-land have a spare 838 / 939 / 1010 pointer (station indicator)?
I think your best bet is gonna be that link I posted above to ATO Audio's replacement pointers. They'll also probably be the cheapest. He makes good stuff--I just received replacement dial lamp holders for my SX-3700 and function & speaker indicator lamp housings for an SX-950 and they are pretty darn solid.
Got it glued , F*^%ing snapped it off again when I was stringing the dial cord #@%^&**) , it came out good just not real bright. Re-glued it , I used the Loctite stuff I posted above. I think it has more to do with the refraction's in the break than the glue , seeing the light blob at the top , if it were crystal clear I doubt it would look like that.
I like the color of the dial face with the warm white LED's . Gotta finish putting it back together and a little work left on the case , adjusted DC offset ,
sounds good and everything works so I'm not sure if I'll get a kit for it or not , all depends on the other 535 I picked up , it has at least one issue but it's cosmetically in great shape.
I'll open another thread for that one.
Question for you or anyone familiar:
The video ATO audio posts for the installation of his " X3X kit" leaves a lot of questions unanswered.
On my SX-939 I'm measuring 7.5 VAC across the two wires that lead to the pointer light. One wire goes to pin 16 and the other to pin 19 (the grounded side of the transformer winding).
As far as I can tell, all he has provided is an LED and a resistor. I believe LEDs require a rectified (DC) voltage to operate properly. The instruction sheet he has provided states:
'Place resistor in series with red wire. Failure to do so will blow the Micro LED.'
Can anyone explain the logic behind this to me?
Here is a link to his product:
Here is a link to his installation video:
