Andrew Heck
Howdy. I'm a circuit novice trying to dig into this piece of equipment and get the most out of it. There are no schematics available, so I've been relying on bits and pieces of advice floating around the internet. The three things that I've found to be important are tube rolling, upgrading the opamps, and better output capacitors. I need your help with the output caps. This is what I got off of one site:
"So being a typical bottlehead, I figured it was time to mess with some caps. I have been unable to dig up a schematic for this device anywhere on the net. If anyone knows where to get one, I would be grateful. So I spent a while following traces on the circuit board, and digging around in the extra cap pile. I ended up replacing the output caps, which were 3 uf boxy things, WIMA I think, with some Solen 3.9s, and bypassing those with some Auricap 0.22s. Also, I replaced some 10 uf electrolytics that I think are cathode resistor bypass caps with 10 uf Solens. Fitting all of this in there was tricky, but doable. Being totally non-scientific, I did all of this at once, so I can't tell you which change did what."
There will be picture on down the thread.
I suppose he's referring to c36-39.
Is changing the values or the quality of the capacitors driving the sonic improvement?
Would it be advisable to keep the values and just improve the type of component? I read that foil capacitors are better than film. Is that close to right?
Knowing next to nothing about this circuit, what would you do?
Thanks for any help you can give.
