CharlieAudio
I purchased a Xiangsheng 728A tube preamplifier. I ran its line output into the line input of my Yamaha A-S501 integrated amp. I fed two inputs to the Xiangsheng, a CD player and an Audioengine B-Fi, which receives wifi and outputs 2.2V on a line output. The B-Fi also has an optical output, which I left plugged into the Yamaha, and which continued to work fine.
The setup plays very low volume even when the volume is near max on both the Xiangsheng and the Yamaha. All six tubes in the Xiangsheng have an orange glow.
The same inputs fed directly into the Yamaha can be played at any desirable volume; I wouldn't go beyond 12 o'clock on the volume control.
The vendor states that the Xiangsheng is "Input Impedance:100K, Output Impedance:600 ohm." The Yamaha manual says its CD and other non-phono line inputs have sensitivity/impedance of 200 mV at 47K ohms.
Is there A) a specifications problem in the relation between these two components, or B) what would be the problem with the Xiangsheng? Thanks for any help deciding whether it is A) or B).
