kjello
I have some questions for the guru's or others with experience or just gut feelings.
I want to 'active' tri amp my speakers (3-way)
I have 3 identical stereo power amps with XLR and RCA inputs. Amps XLR is fully balanced.
My preamp has only RCA output.
I have a 4 way active crossover with XLR and 1/4 jack out- and inputs
Only short IC's are needed.
There are XLR to RCA adaptors available, like mounted on the left in the picture (signal from preamp)
Its also possible to get cables with XLR one end and RCA in the other. Same goes for Jack to RCA.
1. What do you think about the chinese XLR/RCA adaptors? They sell for 2 dollars /pcs ebay stuff
2. Would you rather use decent XLR / XLR cables from crossover to amps ?
I know this is no high end gear, but I have enough good quality Tara Labs RCA interconnects if i choose the XLR to RCA adaptor way.
3. I havent really got the grasp of the 'fully balanced' term, would this mean anyting in this case when the balanced chain is already broken from the source, and only possible between crossover and amps ?
4. What would you choose to do ?
Throw in your thoughts
Best regards
KO
Best regards
KO
