Darkvalley
Member
Hello everyone,
Thank you in advance for your help; I often find solutions here.
I currently have a Yamaha A-1 that isn't in very good condition.
When I turn it on, there’s no click from the main relay (and no lights).
I’ve thoroughly tested everything (on/off switch, fuses, transformer primary and secondary windings); power is reaching the control circuit, and I’ve also removed and tested the power transistors (which are fine). all parts its ok.
I measured the +R terminals and found 12V (after disconnecting the power transistors), which leads me to believe there’s a problem with the control board, but I’m not sure where to go from here.
I was told that the VD1212 diode (D207) was faulty, so I replaced it with two 1N4148 diodes.
Unless I'm completely wrong and don't know where to look.
Absolutely nothing is happening...
Thks !!
Kind regards
L.
Thks !!
Kind regards
L.
