see_what_ha
Hello audio people. I'm a total newb in audio equipment. But the winter is long and I need to fiddle with something cool. I bought Yamaha A-25 / A-500 depending on the market amplifier at the garage sale for 15$. It is a solid state amp. Whatever that means))) there are no lamps.
Looking for some threading wisdom and advise on doing this fix the right way.
Symptoms:
1. when I got it, it was missing few screws from the top cover - someone was messing with it.
2. It powers on.
3. When I hooked up my turntable to it, it had no output whatsoever. After I pushed source selector a few times it started to play. All controls started to work afterwards. And plenty of power on output, was afraid neighbors would start to complain. Could it be that the source selector is "clogged" ? Also, I attache the image of push source selector assembly. Each selector has a little hole on top, is it for Deox to clean it?
4. From visual inspection it appears that two "main" gigantic caps are leaking. Goo at the bottom. Also see the picture attached. The amp was made in early 80's, but I'm not sure if the caps where replaced later on. Question: Is there an easy way to diagnose a cap? Is it even worth the time? Should I just replace it?
5. If I just go ahead and replace it? Any suggestions for the product to replace it (something with good quality/value balance) See picture for brand and info on caps.
6. Is it worth replacing smaller caps? None of them appear to be bloated or leaking.
Any advice or link to the info is greatly appreciated.
Symptoms:
2. It powers on.
