Yamaha A-550 — left channel very low volume, full volume in mono — help diagnosing
Space_Boy_Bo
Hi all, hoping someone with A-550 experience can help me diagnose a left channel issue.
I purchased a a A-550 off of FB marketplace relatively recently. The amp has been working fine, but recently the left channel volume dropped to about 10% of what it should be. Right channel is perfectly normal.
Here's what I've already tried:
- Swapped speaker wires left/right at the amp — problem stays on the left channel, rules out speakers
- Tried multiple input sources — same result on all inputs
- Cycled the volume and balance pots repeatedly — no change
The interesting clue: when I switch to MONO, the left channel comes in at full volume.
From what I understand, this suggests something in the left channel signal path — possibly a failing coupling capacitor, a cold solder joint, or a differential pair transistor issue. But I wanted to ask here before touching anything since you folks know these amps much better than I do.
Amp is otherwise original, hasn't been recapped. No physical trauma.
Any known weak points on the A-550 that match these symptoms? Happy to take measurements or photos if that helps diagnose.
Thanks in advance.
I’m fairly sure the issue is in one of the selectors or switches. I’d start by fully cleaning the Stereo/Mono switch itself first. Do not touch anything else at this point, especially any active components.
Don't know the amp...
Schematic shows the stereo/mono selector immediately after the input selector and before any preamp gain stage.
Indicates input selector or stereo/mono selector as per sparkplug. You could try working these switches like 20 times noting any change (good or bad) would point to that switch, cleaning would then be required.
Problem solved, and I owe you all an apology for wasting your time.
After all the thoughtful suggestions — turns out it was a loose connection in the tonearm headshell on my turntable. I had methodically swapped speakers and tried multiple inputs, but embarrassingly never tried a completely separate source like a phone or CD player plugged directly into the amp.
The left channel on the amp is perfectly fine. The issue was upstream the whole time.
Lesson learned: always verify your source before diagnosing the amp. Thanks for the help and sorry for the false alarm.
