Yamaha A-550 - Static on the right channel
Baube
Hi everyone, my yamaha A-550 recently started having intermitent static on the right channel, but only when the volume is over 2, sometimes even when nothing is playing. Any ideas?
We already have isolated the problem to the amp (tried with different speakers and different sources), cleaned the pots and changed the leaking caps. I'm not sure where to go from there.
Find the protect relay ( RY301) and lightly tap on the relay while listening to the output. Listen for static increases or decreases..
I'm not sure how the A-550 [ganged] volume pot(s) are set-up to handle varying degrees of volume level, but I'm wondering if some of the soldered connections from your volume pots on the volume printed circuit board may need to be re-flowed - especially the lower resistance pot for the right side channel.
