spaghetti
I recently purchased this great amp on the famous auction site, I spent a few days disassembling it and cleaning each and every part, putting everything back together, and finally today I decided to test it... with VFETs safely removed, of course
Voltages are quite fine, +85V is slightly lighter at 82.5, but being spot on should be just a trimmer adjustment away. I noticed that, after turning the amp off, the VFET +59V and -59V rails on the left channel bleed out quite fast, while the other channel rails stay high for a very long time. I think that the right channel is behaving correctly, as there is no load attached to the wires (no VFETs), so they should not discharge.
I may start my troubleshooting by swapping the big caps, and see if the issue moves with them... or am I overlooking something more obvious?
