david winter
Classical music lover.
Hi,
I'm trying to figure out what can cause the -85V supply to drop to -60V when the bias increases up to around 40mV.
With no bias, I get the +85V and -85V voltages correct.
Adjusting the bias on either channel makes the -85V drop down to -60V.
I checked the transistors on the negative rail and didn't find anything wrong. I only replaced a 2SA872 with insufficient gain and a 2SC1439 with too high gain (could be ok but I preferred replacing it).
I'm not going into overhauls, but so far I did the following:
- Electrolytics replaced (including the big ones on the psu)
- Replaced all 2SC458/2SC1345
- Replaced both protection relays
On the power output boards, I replaced:
- All fuse resistors by non-flamable ones with correct wattage
- The four 0.1µF
- All 2SA810 (TR107, TR108, TR109, TR122, TR124) by TTA-004
- All 2SC1452 (TR110, TR121, TR123) by TTC-004
- Bias trimmers by multi-turn ones
Diodes D101, D102, D110, D111 test fine at 1.36V-1.4V
The input N-FET (TR104, TR105) test very close, so I don't think they are causing any trouble.
Vgs-off: -0.44V @ Id=5.1µA / -0.46V @ Id=4.6µA
Vgs-in @ Id=5.00µA: 0.18V / 0.19V
gfs @ Id=3.0mA to 5.0mA: 14.9mA/V / 14.2mA/V
Idss = 2.43mA at Vds=2.99V / 3.01V
Rds-on @ Id=5.0mA: 50.1R / 55.4R
Any help welcome
- The four 0.1µF
Any help welcome
