Have to apologize for my slowness on this. Too many irons in the fire (sick mother, mostly) and end of the third quarter at school.
Here are a couple of pics. The blank is fine. Just needs slightly larger holes. However, the terminal mounting plate is not and has to be redrilled. I will redraw and have on its way today. I'll go through one more iteration before I would say they are safe to have made as a 'production' run. Although I did not think of it at the time, the blank plate will mount nicely on the inside of the back-plane, as will the terminal block. If you want them to be black, simply rough with some 2-300 grit sandpaper and spray the one surface. At least that is my plan.
You'll know more when I do.
