Hifibythekg
This amp appears to be working well in all regards except that there is a significant hum when Phono is selected.
The hum also comes through substantially on Aux and Tuner.
Hum appears to be stronger through the left channel.
Hum is lessened when ’Tone Bypass’ is selected, but disproportionately so I think.
When a source is connected to either Aux or Tuner the source is ‘perfectly’ amplified without hiss or crackle, all controls work and adjust the sound as they should but when the performance ceases the hum is present.
In an attempt to trace and fix this the following has been done:
Thoroughly cleaned the wafer switches (albeit in-situ).
Inspected, flexed and tapped the wafer switches to see whether the hum is affected. It isn’t.
Inspected, checked and tapped all solder points on the RCA board.
Tapped the all easily accessible boards wherever possible. No sounds or affect on the hum occurs.
Touching ‘Ground’ by the Phono RCA outputs, or any of the RCA outputs doesn’t produce even the smallest change in sound.
Can anyone advise?
Can anyone advise?
