Enobenetto
I have both a Yamaha B-2 and the Nelson Pass DIY VFET amp. I bought some NS-1000 years ago and the seller installed dual binding posts for bi-amping (he also upgraded the caps). When I get my Yamaha C-70 fixed, is it possible to use the inverted out and normal out, so that I can bi-amp the Nelson Vfet to the midrange and tweeter, as well as the B2 to the woofers? The manual shows how you can use the inverted jacks with one stereo amp, by using one inverted input and one normal input, so I wondered if you could bi-amp with the other unused inputs?
Also, speaking of the C-70, the input jacks on the pre-out are loose and drop the connection. Could I swap the input jack module from phono 1/2 with the preout ones? They look the same, but not sure, and don't want to mess anything up when I desolder them.
Thanks
Thanks
