Yamaha C-85 question
edwin
I noticed there are provisions for 2 turntables on the C-85 but the front panel only has 1 phono button. Does this mean that the preamp will detect automatically which of the 2 turntables are playing? Thank you.
The phono selector switch inside the flip down panel selects phono 1 or 2. Phono 2 must be a MM cartridge.Phono 1 can be either a MM or a MC cart.
So this means the first switch with "2/47 220pf" is the selector for phono 2. Am I correct? Thank you.
If by first switch you mean the one all the way to the right, yes. That one position is for phono 2, all the other positions of that knob/switch select phono input 1 with various options for cartridge loading.
