Mat86
So I recently attempted restoring a C4 and noticed this issue out the box, I was sometimes getting no volume on AUX, or just 1 channel, but switching to Tuner solved it so I assumed it was an Aux input issue or dirty contacts
during the recap I did a test half way through and had volume in both channels and pre-out to another amp was seemingly fine. When I was done it was working as well.
Left it to burn in over night and a few hours later listened and noticed the left channel was out and the sound itself was muted (as in, off, dampened). Tried Tuner and it was fine, so back where I started at least.
...then the Tuner input went on me. I noticed that jiggling the switch between Aux and Tuner would get the left channel going again, but it wasn't consistent. I then noticed that rebooting the system was 100% consistent in restoring the volume in both channels.
Fast forward, but I now tried the Phono stage and it did the same crap, but toggling the Phono knob (its a different knob than the input one) got it going extremely temporarily (like mid rotation)
So here I am:
So here I am:
- Various channels lose 95% of volume (not all, its just quiet as hell)
- Affects multiple inputs
- Power cycling fixes the Tuner input, but not Phono
- Seemingly not an output issue, since the headphone amp is n different from pre-out, and mono outputs both channels while stereo/reverse alternates the signals fine
- Yes, I've blasted the ever living crap out of the switches with cleaner
