Okay... status update from the beginning.
Cleaned all switches and pots with Craig products.
From what I can see, the wafer switch contacts look pretty good.
My next step was to replace caps 519, 520 and 520. It was clear the glue and/or heat had damaged the leads on one of them because when I touched it, one of the leads broke.
I then went after the transistor on the small heat sink since it was just dangling and there was a lot of glue residue around its base. I removed it but damaged the pads. Reinstalled with a silicon pad and washer... may later go back and use paste instead if/when it makes sense. I used some automotive RTV to glue the sink to the board, and made some jumpers because of the damaged pads.
Then as a precaution I went ahead and changed out C313, with a Nichicon with the same specs.
Then I decided to go after the other two heat sinks. Removed them... this time being more careful and using solder wick, which seems easier than a suction device in my inexperienced hands. Still managed to damage pads so had to use a couple more jumpers. Again, used silly con pad and washer to insulate the TR from the sink since that is what I had on hand. Screwed both sinks to the board.
Then I decided to go after the nearby VD1212.
Fired it up and I had hum on all inputs and a weak channel. But she would not shut down after about 30 minutes of power on.
Before troubleshooting any further, I decided to replace all 1212's on that board as a precaution.
Then I fired it up and and presto, like magic she made music, but with hum present on all phono inputs.
I decided to go after the 1212's on the headphone board this am.
Next I will adjust the 30VDC and offset, then I measure some voltages and try to hunt down the phono input hum.
If I get that sorted, I will order and then replace caps for the headphone board, since the originals have signs of deterioration.
During one of my tests, the neck of the headphone jack broke off when I removed my plug. Old plastic. So I will eventually deal with that. Right now the hum has priority.
I will do some search here on AK to learn about potential causes of phono input hum, and study the schematic as well.
