I used mostly UFW Nichicon, one of their audio caps. Why did I use audio caps, well because Nichicon has decided to market them as audio caps and there must be something to that because they look better than the turd brown caps other lines are covered with and I did see that Sony used Nichicon Audio caps in their top of the line ES 5.1 receiver or whatever is laying dead in my entrance foyer. If Nichicon and Sony think there is something to it, I do not care what any AKer that is not a modern electrical audio equipment designer or a current capacitor engineer at a major capacitor manufacturer says. That cost me an extra few bucks but I believe the total of all the new crap I threw into the unit is under 50 bucks. C-4 as is working, 200 worth, recapped, maybe 400 worth, time to install all those parts...who cares it is a hobby and I like my new soldering iron. Taking time: cleaning the switches, wrestling with the function controls, still not part of the equation. Then the multiple hours of removing the slider switches, the long ones between the function switches, time I will not get paid for when I sell the unit, if that were to happen. I have three tts it has three tt inputs. I need more high level inputs but I have a switch box for that.
As to sound quality, this unit was picked up with some Crown amps, a JVC tt, Onkyo tuner and full Dahlquist DQ-10 system with one sub and electronic crossover which is what I wanted at that time. I didn't really use the C4 before a recap and then had trouble with it missing a channel that Dave explained how to fix, clean the long phono loading control switches on the board. Although the preamp is in the main rig right now, I haven't gotten serious about comparing it to the preamps that are usually there because of the dropped channels that happened when installed prior to that fix as well as a dropped channel in a turntable with one specific cartridge. I hope all these channel issues are resolved. I do have other cartridges but this one has no wear.
I probably need to leave it in the rig until I learn all the controls because I can't read that fine white writing on the black faceplate in the dimly lit room. Think I'll do that, thanks for making me think about this preamp.
Caps, transistors, variable resistors, diodes, resoldering, cleaning, removing and cleaning. Quite a bit of work but none of it hard or expensive. Results are worth it. I don't like having gear that doesn't sound good in my system. Took me less than an hour to replace a bad sounding tube unit that I replaced the coupling caps in when it was breaking in. It sounded like crap the first two times I plugged it in and had to leave the house while it did the break in over a few hours.
Go for it.
