Yamaha CA-1000-crackling coming from inside casing. Help!
Josephw12
Recently bought a CA-1000 off EBay.
Listing stated:
The unit has been repaired and serviced, and it is in good working condition with clear sound output. The block capacitors, deteriorated transistors, electrolytic capacitors, resistors, and lamps have been replaced.
The switches and volume controls have been cleaned with electronic parts cleaner and treated with contact restorer. There is no noticeable crackling noise, and the sound output is smooth and stable.
The power circuit has been adjusted, including DC balance and bias adjustment. The cabinets, front panel, and knobs have been disassembled and thoroughly cleaned.
The terminal section and all connections are in good condition. The bottom panel and insulators are also well maintained. The internal components and circuit boards are clean.
everything seemed good for a couple days and then started to notice some questionable things.
Symptoms, in order of appearance:
1. A fuzzy/hissing noise audible from the speakers, even with the volume turned all the way down. This is audible from about 5 feet away in a quiet room, on all inputs (Tuner, Aux, Phono, Tape).
2. When using the Phono input specifically, this noise scales up noticeably as the volume is increased — even with nothing connected to the Phono RCA inputs at all.
3. No hum or buzz at any point — the noise is strictly hiss/fuzz, not 60Hz hum.
4. Scratching when operating the “Loudness” knob.
5. Most recently, I’m now hearing a crackling/ticking sound coming from inside the chassis itself (not through the speakers) — it sounds similar to a Geiger counter.
Frankly, I’m clueless. This is my first amp, so I don’t even know what to think. Would appreciate any help at all.
Possibly the class A snap action switches are misbehaving. Toggle the Operation switch. See if the crackling gets better or worst.
  • Like
Reactions: mbz
The blurb from the seller is concerning. It sounds like they're reciting learned bullet points without really understanding them.
It does not inspire confidence in the quality of whatever work they did, and the issues you describe are not exactly trivial.
Assuming you paid full price for a unit that was advertised, falsely it turns out, as without issues, you're well within your rights to either return it or negotiate a partial refund to cover the cost of the repairs.
Beautiful amp, though!
Yes, there's something not quite right about the details.
Buying a 40-50 years old vintage integrated amplifier is taking a chance.
Normally, I would buy if it is still in original condition so there is a baseline of expectation.
One more things, certain parts cannot be procured.
Once, I did buy a 50 years old amp and I waited for more than 2 years to get a donor parts from Ebay but this amp was never touched.
After carefully restored with some modern parts, the specs exceeded the OEM.
That’s interesting. When I power it on in Class A, there is no crackling. Only when I power it on in normal. So you may be on to something. The noise coming from the speakers happens in both settings, so idk if that means I’m experiencing two problems simultaneously.
Well, he’s not responding to my messages so far, so who knows.
If he keeps not responding, after a certain time eBay will refund you (and charge him back). I think it might be 30 days but double-check.
As a buyer, eBay is definitely on your side. Only communicate with the seller through eBay's platform and you'll be fine.
Yes, it is about 50 years old and Yamaha is not known for stocking old parts.
I started restoring a CA-610 II (CA-1000's little brother), and off the top of my head I can't think of anything in there that's not repairable, replaceable or substitutable. But maybe the CA-1000 is different in that respect.
I restored one a while back and as far as I remember, it's all do-able. No unobtainium inside. Big caps and power transistors are expensive but that's it.
The 2 snap action switches need to be replaced. :thumbsup:
I appreciate your help so much. Unfortunately, I’m probably not skilled enough to make the repair myself. So on to find a tech. Do you think repairing these switches will also solve the other problems?
1. A fuzzy/hissing noise audible from the speakers, even with the volume turned all the way down. This is audible from about 10 feet away in a quiet room, on all inputs (Tuner, Aux, Phono, Tape).
