triodo
Hi guys,
My Yamaha blows one of the fuses installed after the transfomers : it happens when I switch in Class A mode.
This doesn't happen all the times that I use the class A mode.
See the red square in the the wiring diagram : is one of the two fuses on the lines OR-OR-->fuse values are T6.3A-250V
Do you have suggestion?
Could be the relay the problem?
No problems in class B .
Power supply in my home is 235V so the voltage selector is on 240V.
Thanks in advance for your help.
bye
Yari
bye
Yari
