I have a problem with a CA-2010 that I hope someone who understands a schematic could help me out with. I have done my best to read up on the various threads already available on the topic of CA-2010 going into speaker protection.
The relay clicks (closes) a couple of seconds after powering up, and all is good.
After a minute or two, the relay breaks both channels, and then typically remains open for anything from a few seconds to about a minute, maximum, and closes again. Then, as the amplifier continues to warm up, the relay can break one or two more times, but once the amplifier has reached working temperature, it works and plays.
I have replaced all electrolytic capacitors (on all boards), as well as the speaker protection relay. After some further consideration, however, it seems to be a semiconductor issue, considering the temperature dependence. Or perhaps a bad solder joint.
+B3 voltage from the power supply board is stable at about 11 V, which I presume should rule out problems with supply voltage to the speaker protection circuit? Also +/-B and +/-B2 are close to spec, if that matters.
The problem remains when the Pre-out switch is open, which I presume should rule out DC from pre-amp and tone control?
Voltages between TP1 and TP2, and between TP1 and TP3, have been set according to service manual when the unit is warm.
While the unit warms up, the voltage between TP1 and E on the right-channel main amp fluctuates slowly, but with a large amplitude (typically, a couple of 100 mV). Then, at some point, the voltage rushes rather quickly up to a few volts (up to about 10 V, max), and the protection relay breaks. As explained above, this can happen a couple of times during warm-up, until everything stabilizes after some 15 minutes or so. TP1-TP2 remains stable at 25 mV also while TP1-E fluctuates. The test-point voltages of the left-channel main amp do not fluctuate.
I guess this, in combination with the other tests described above, could point towards semiconductor components of the right-channel main amp. Is this correct? If so, does anyone familiar with the CA-2010 have any suggestions for which components would be the main suspects, or any suggestions on how I could proceed to narrow it down further? I sure can replace components, but unfortunately I’m not skilled enough in electronics to figure out how the circuitry actually operates in detail.
Thanks!
Thanks!
