Yamaha CA-610 II problems
tyttuut
I just finished recapping and cleaning out my CA-610 II. When I plugged it in, it didn't catch fire (yay!), but there was no relay click.
I decided to check the test points near the power transistors. One measured a little high, which I corrected. The other one reads 0.4-0.5mV. Twiddling VR482 had no effect, the voltage stayed at the same level.
The service manual mentions checking the voltage between E and TP2 or TP4. Is "E" the emitter of TR574?
I'm not sure if this is relevant, but the meters and their bulbs are disconnected on both channels.
Quick side note: I put a beefier heatsink on TR572 because it looks like it had been running hot (the board was discolored).
What TP's ? And why are you twiddling ?:biggrin:
I'm talking about TP1 and TP2 (left channel) and TP3 and TP4 (right channel). The right channel is the one giving me trouble.
Also, when I say "twiddling," I mean I was turning the pot. Honestly not sure why I say that!
OK... Clip your black ( neg) test lead to the metal chassis (E). With your red test lead probe TP-2 and then TP-4. Report your DC voltage readings.
What voltages are you reading ?
17mV on the left (I fixed that one) and pretty much zero (0.5mV) on the right.
Was this CA working before you started working on it ?
To the best of my knowledge, it did work. The only problems were iffy audio quality and a very delayed relay click (several minutes).
This is the idle current or bias.. That channel is " borked".
Crap.
It turns out I was measuring the wrong combinations of test points (1+3 and 2+4). I measured the right combinations (1+2 and 3+4) and now I'm seeing about -42.5 volts (not mV!) on both channels. I really hope I'm measuring it wrong!
The voltages you asked me to check are the same: -42.5 volts. Like I said, I hope the problem is between the keyboard and the chair.
OK, the service manual is a little ambiguous here. It has a diagram which shows how to connect the leads, which shows that I was doing it right before (1+3, etc). The text says to check between 1 and 2.
If TP2 and TP4 are at -42volts indicates both channels are" at rail" either shorted outputs/ drivers or something is holding the outputs and/or drivers at rail.
Next voltage measurement. Put the fuses back in the circuit. With your black lead clipped to the chassis. Probe the output transistors metal case(collectors). Be careful not to slip and short the transistor cases to the heatsink( ground)
Two of the transistors should have +42.5vdc and two should have -42.5 vdc.
=Two of the transistors should have +42.5vdc and two should have -42.5 vdc.
That's what I'm seeing, about +/-44V
I checked the resistance across the speaker outputs, and both are shorted. I'm guessing that shouldn't be the case! :dunno:
