ScooterMcTav
I know less than I think
Hello all,
Found the above mentioned receiver at the local electronics recycler, and was hoping to get it fired up to test head-to-head against my Sony STR-5800.
When doing initial checks (power on, and DC offset checks), I did not hear the normal noise of the speaker relay switching on, and I had zero DC at the speaker terminals. Also tried toggling the speaker switch off and on, and still no speaker relay click.
A couple of taps with the handle of my screwdriver, and again, no relay click.
I performed a detailed visual inspection of the unit, and saw no obvious signs of a failing part, nor any bulging or leaky caps.
Both visible fuses were removed and checked for continuity, which they passed.
Possibly related, there was also no light on the VU meters.
Suggestions as to where to look next? Anyone else had similar issues?
Thanks all in advance.
