Got a Yamaha CA-800 Amp that the Right Amp Board needs a rebuild. Reading threads on transistor substitutions it appears that KSC2690 is a good sub for the 2SC1124 transistor. The issue I have is that the 2SC1124 is EBC while the KSC2690 is ECB. This would not normally present a problem when the board layout is in a triangle configuration, but in this case the pins are arranged in a straight line. This requires a twisting of the legs of the KSC2690 in an X pattern. I can insulate the legs from each other and make it work I think, but it's a convulated mess.
My question: Is there a good sub for 2SC1124 and 2SA706 that has a pin layout of EBC?
Thanks so much for your help.
